3/4 ton caliper question
Discussion in 'The Garage' started by wraenking, Jan 19, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i need the bolt that connects the brake line to the caliper. the caliper is form a 78 chevy pickuo 3/4 ton. no one seems to know what to give me. anyone know the size, or could you see what size your is?
    thanks
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I just went down to Napa and got one to fit the caliper. Mine were from a 75 3/4 ton but yours should be the same.
    It is called a Banjo bolt. I will look for my reciept to find the part number.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    thanks. iwould rather not take the caliper off again.
  4. readymix
    May 30, 2004
    6,706
    26
    The reciept did not have a part number?? Just a description and price. Did not tell the size or thread count either. I would just head down to the parts store and tell them what the caliper came out of and they can pull one off of the shelf and match a banjo to it.
    Be sure to get new crush washers too.
  5. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    1/2 ton and 3/4 ton calipers are the same EXCEPT that fitting on the 3/4 ton caliper is metric or bigger I forget which, so with my 3/4 ton setup I ran SS lines for a 1/2 ton with 1/2 ton calipers so I could retain the lines and stock app stuff.......
    if you choose to use the 3/4 ton calipers I believe you'll need 3/4 ton lines as well b/c the hole size in the part of the line that bolts to the caliper is diff if I remember right.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    10 bolt calipers are metric thread, 10mm. If they're D44 calipers it's a 7/16-20. Just look for the banjo bolts in the Help! section.
  7. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    just called napa, and he said he needs to know the length.
  8. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, i got it.
    its help ppart number 13935
