3/4 ton conversion joint question.
Discussion in 'The Garage' started by Brady, Apr 13, 2003.
  1. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I am putting a 350/205 combo from a 1/2 ton into my '86 3/4 ton Sub.It has the SF 14 bolt.Is the conversion joint for the 3/4 FF 14 bolt the same?Thanks Brady
  2. Brady
    May 6, 2000
    628
    Parachute,Co
    Nobody knows this?
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, the 1/2 ton driveshaft uses a 1330 joint. And, I believe the 14 bolt SF uses a 1350 like the FF. (So yes, it would be the same conversion joint)
    Someone correct me if I'm wrong. /forums/images/graemlins/ears.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    actually it is a 1310/1350 joint.i just got one a couple of weeks ago to put in my 14 bolt.maybe yours has a 1330 yoke but mines a 72 blazer and maybe they changed the yolk size.neapco part number is 3-3140.you should be able to take that to the parts store and cross reference the number to whatever company they carry.
  5. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    If he is talking about his 86 1/2 ton...then it has a 1330 joint. The 10bolts came with a 1330 yoke...while your 72 came with a samller 1310 12 bolt yoke.
    Blake
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Napa part either 348 or 447............
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Or 448.. I found that at the hard way..LOL
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Why didja need the 448? Is it a tad wider on the cross that goes to the 14 bolt yoke? I've got a 447 now, but it seems to be about 1/8th of an inch or so too short on the axle yoke side. /forums/images/graemlins/frown.gif
