3/4 ton conversions having its issues
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by makovai, Oct 30, 2006.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    Before this whole thing started i picked the wheel and tire combo i wanted, and had this planned out fairly well (i thought). I have now completed the entire front end, and i have ended up with a rig that doesn;t have the turning radius of a stretch limo.
    At first i had issues with about 1 foot of tire sticking past the fender wells, so i went to a narrower wheel with more backspacing. I sucked alot of tire under the fender, but now i hit my shocks and brake lines if i turn the wheels very far.:mad: . I'm getting frustrated. And the front is posed to be the ez conversion.
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    dayum, those are the narrower tire?
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    relocate the shocks and tie the brake lines tp them
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Well, it's looking good, to bad about the turning radius. Is there anything that can be done to recoup some of the turning radius?
  5. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    On a totally unrelated note -that thing is going to look sick when it's finally done - and it's gonna be HUGE!
  6. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    What back spacing did you end up using?
    4" is the most I've ever been able to make work.
    Try using Ford shock towers and relocate the shocks, that'll help.
    Change out the brake lines to braided (longer) ones too.
    Have you installed cross over steering yet? Another good mod IMO.
  7. makovai
    Jun 6, 2006
    854
    oregon city
    actaully these are not the narrower tires, however they are the narrower wheels. i believe 3.5" backspace and only 12" wide compared to the 14" i had on earlier with almost no backspacing. They look great except for the 12" of tire that stuck out of the fender wells:D
    The tires are 39x18 mickeys with alot of tread left, at least 75%. I did pick up a set of 39x15 mickeys as a backup plan but they are about 25% tread. If i use the 15" wide mickeys i could get less backspacing and it may work, but i was after the wide look. I geuss i could lose the dual shocks and tie the brake lines. It just wasn't in my plans to do that.
  8. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    You can always put the outer dual shock back on - most people aren't going to be looking at the shocks on that rig anyway
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I have a home for what ever tires don't work.
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    wow. the wide look IS cool, but those things are nuts. i dunno if you'll be able to get much in the way of turning radius with those tires.
  11. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Rear Steering
    Rear steering, that's what you need :D !!
    Rig's looking great :bow: !
  12. makovai
    Jun 6, 2006
    854
    oregon city
    Actually that would be cool. It would definately be different.
  13. makovai
    Jun 6, 2006
    854
    oregon city
    New update:
    The front is finsished. Now i have the 12 bolt out and the 14 ready to go in. my newest issue is the truck is trying to teeter totter on the jackstands and i dont have enough room in my garage to come through the side. I have a jack under the tow hitch and i need to move it to get the 14 bolt under the truck :mad: This project is not fun.
  14. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    if the truck is teetering front to rear, and the front is supporting itself on tires, jack the truck up and off of the jackstands and move them backwards. should free up the jack for you.
  15. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    My K5 is sitting almost exactly like your right now - 14 bolt is out getting its Detroit installed. Do get those jackstands move a bit if it really is unstable - wouldn't do to have you get squished!
  16. makovai
    Jun 6, 2006
    854
    oregon city
    I cant. The jack stands are as far back as i can put them. The frame goes way too high to reach about midpoint of the truck.
  17. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    It's all about big lumber.... :wink1:
  18. makovai
    Jun 6, 2006
    854
    oregon city
    or taller jack stands so i can hold it up in the back of the frame.
  19. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Got anything heavy infront of the truck, like an engine block, or big tool box??? If ya do, ratchet strap from around front bumper to something heavy at floor level-will add more weight to the front end.
    Then you can lower the floor jack and slide the rearend in place. If you still have the big tires on front, lower the air, so the nose dips down.
  20. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    put those jack stand heads under the front spring eye. or slide them back just in front of and place a chunk of wood or steel across them both.
