3/4 ton D44, 14ff install
Discussion in 'The Garage' started by chev4life, Feb 12, 2004.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Getting d44 3/4t and a 14ff w/ disks for my 87 /forums/images/graemlins/woot.gif and have a few Q's for you guys. First, the D44 has a single shock mount on it and my rig is setup for dual should I just live with the single and not worry about it or should I hunt down a dual bracket and weld it up? Second for the 14ff disc breaks...can I just hook up my break line and rock on or do I need to upgrade the master cylinder?...regulator?...whatever? Just trying to figure out how to set it up right. Do any of you guys use spacers on your 14ff to even out the width with the front? Where/what to get if you do? Will my stearing arm from my stock 10b fit the d44? Last question...where is a good place to get a set of u-bolts and top plates for the rear?
    Thanks for any help, if you think of anything else I should look for to do this swap please let me know. /forums/images/graemlins/peace.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You just need a longer bolt through the shock mount at the axle to accomidate 2 shocks, that is how your current setup is( I would imagine).
    You will need different brake lines for that front 10B but don't throw the old ones away because a 10b and D60 share the same size brake line fittings. Your rear brakes should bolt up just fine and no... you don't need to do any mods to your brake system besides the front lines.
    You will need a conversion u-joint at the yoke on the 14BFF, the best one available is a neapco joint, part # 2-1153.
    Hope I helped a little. /forums/images/graemlins/thumb.gif
  3. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Cool, longer bolt is what I was thinking and there isnt much load in shocks anyhow.
    I thought my stock lines would hook up to d44 in the front..how are they different? I was gonna go with a set of braided lines throughout so do I need 3/4 ton line set instead of 1/2 ton line set?
    Thanks for the info! /forums/images/graemlins/thumb.gif
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Actually there is a spacer between the two shock eyelets to keep the shock tubes from rubbing togethet, it's anout 3/8 to 1/2 inch thick. along with the longer bolt too. /forums/images/graemlins/waytogo.gif
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    If your current setup is with dual shocks, then just reuse the hardware that is on the bottom of the shocks, it's just a longer bolt with the spacer i mentioned before.
  6. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Cool deal guys, I noticed the spacer but didnt remember the whole setup since I dont have my truck around.
    How about the rear spacers? Stearing arm? Front break lines?
  7. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    d44 break lines are different but I "beleave" 10 bolt lines will work on a 10 bolt, but not the other way around. Not shure though. /forums/images/graemlins/deal.gif
    steering arm, just a raised procomp arm from 4wp is about 60 bucks. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
    -shawn
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I reused the stainless extended brake line that I used with the 12b when I put the 14BFF in. I had to run new hardlines on the axle to the flexible lines at the caliper.
    I did not need to upgrade the MC or prop-valve. I just gravity bled the brakes and they work quite well.
    I am not using spacers. There are a couple of places from which to purchase them. TonyP here on CK5 makes them.
    Yes. /forums/images/graemlins/waytogo.gif
    For spring plates, I would suggest a junkyard. Your local spring shop can make u-bolts to the diameter and length you require.
    Good luck in your swap. I know I was grinning ear to ear once those nice rebuilt axles were under my truck! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  9. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Awesome, almost set now, need to grab a set of spring plates, u-bolts, braided brake lines (still not sure on the front though????), spacers maybe someday, tire/rims, got the u-joint, and need lots of beer and I think I am set. /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    For the front brake lines...tell them you have a Dana 44, not a 10B and they should get you the right lines. There is no difference between a 1/2 and 3/4 ton caliper on a D44. The difference between a d44 and 10B caliper is the brake line fitting that bolts to the caliper .
  11. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Cool, sounds good to me. Thanks for the info...cant wait till these bad boys are on!!! /forums/images/graemlins/woot.gif
  12. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    You could probably also just use the calipers from the 10 bolt on the D44. Some interchaneg and some don't, but you could always try. That would eliminate one messy part of the project and save you some money.
  13. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I can hook you up with the top clamp plates and spacers...
    [​IMG] [​IMG]
  14. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    Ooooh pretty [​IMG]
  15. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    that's what i did. i re-used my complete 10 bolt outers and they bolted right on to my 44. /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  16. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Nice brackets TonyP, we have talked briefly on email about your 8-6 lug conversion...not doing that anymore /forums/images/graemlins/waytogo.gif so what do you charge for those badass 8-lug spacers?? How thick are they? I already found me a set of sprign perches, but no where near as cool as those /forums/images/graemlins/peace.gif
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    i have a set of 1"inch thick ready to go, PM me...
  18. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I cant PM since I am not an "offical" member. What is your email?
  19. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]Hmmmmmmmmmm /forums/images/graemlins/thinking.gif hint! hint! /forums/images/graemlins/grin.gif
  20. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Oh yeah, check out that color now /forums/images/graemlins/peace.gif
