3/4 ton D44 with axle housing crack; Would you buy or part out?
Discussion in 'The Garage' started by la_blazer82, Sep 22, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I located a 3/4 ton D44 with 4.56 gears to swap in the front to match the 14bff. Only problem is owner says He "put a bit of a crack in the center section and I don't think anyone would want it after that (but it isn't a big crack and the tubes could just be welded all the way around."
    Would this fix the problem and make it sturdy? I would prefer a beefy 3/4 ton over my 1/2 ton 10b. Should I buy the entire axle since it has the gearing I'll be changing the rear 14bff for, or should I just buy the 8lug parts to convert my 10bolt.
    I would have to do the gearing in my 10bolt if I convert.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd buy it, weld it, and run it.
  3. la_blazer82
    Apr 12, 2004
    148
    SoCal
    The other problem is that I don't weld. How much would I be looking at to have the axle tube welded?
  4. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    go back to the socal site we have a couple of welders in the club!!!
    AKA 74BLZR /forums/images/graemlins/weld.gif
  5. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Just wanted to know whether I should jsut buy the outers and backing plates. Seems as though it would be a decent buy.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You could always transplant the guts into another case, also.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Weld it and run it as long as the crack isn't real bad or anything. Maybe even truss it for piece of mind. /forums/images/graemlins/thumb.gif
    Same axle just different outers /forums/images/graemlins/waytogo.gif
  8. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    http://coloradok5.com/axleswap.shtml
    Comparisons of some of the different axles....
    Steve's truck used to look purdy sweet, now it's looks purdy sick (in a good way). /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
