3/4 ton Dana 44
Discussion in 'The Garage' started by SF87K5, Feb 12, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    /forums/images/graemlins/1zhelp.gifWhat years did the 3/4 ton come with a dana 44 front axle? I am looking for a 8 lug D44 for my K5. I have a buddy that has a set of the moser axles he does not want anymore. I can get them cheap from him I just need a 3/4 ton dana 44.
    /forums/images/graemlins/1zhelp.gifPlease help
    Thank you everyone
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    i think 73 -78 but not sure someone will correct me if im wrong
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Buy any Dana 44 for a chevy and swap it over to 8 lug. My 10 bolt started life in an 85 Blazer, add some parts from a 74 3/4 ton 44 and Voila, 8 lug 10 bolt.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    any dana 44 from 71 on to 78 can be changed to 8 lug by changing the spindle,backing plate and hubs off of a 3/4 ton axle.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would have to say get a 77 or 78 3/4 ton D44 or just swap 3/4 ton 10B stuff onto your D44.
    The reason I think that is the best solution is that the 77 and up axles use the stronger spindle and bigger inner bearing as well as using the internal locking hubs.
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    isn't there a HD version or is it just the bolt pattern difference? something about a weak ujoint or something.......??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The 77 3/4 ton D44 that I got has a thicker center section where the short side axle tube goes in...I couldn't use the old u-bolt I had for the one that goes around the pig. It was about 3/4" too short!
    I think some people think the external locking hubs are "heavy duty"...they arn't...you also have to worry about the stupid bolts that hold them onto the hub comming out (which I have seen way to much of on other guys rigs that say they used locktite and torqued them down real good). The external hubs are also more $$$ when you need to replace them.
  8. Kyle89K5
    2,273
    OKLAHOMA
    I'll agree with part of what you said, they are no more heavy duty. I will have to disagree on a few other things though. My hubs didn't cost any more than the last set of internals I bought. The only hard part about them was not everyone has them sitting on the shelf. One call to ORD and they were at the office. Plus I got a cool set of drive flanges that I tend to use instead of hubs anyway.
    As for the bolts backing out, I haven't had one loosen AT ALL. All are loc-tite'd torqued and use lock washers. They are hell with the lid off to get off, but they just don't back out on their own.
