3/4 ton driveshaft question
Discussion in 'The Garage' started by gravdigr, Jun 21, 2004.
  1. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I am buying a 77 3/4 ton truck for the drivetrain to put in my 79 blazer (only 1 more $100 payment and it's mine). The truck has the sm465/205 combo and a 14bff rear with gov loc. He ran it with a lift and it has an extended front driveshaft /forums/images/graemlins/thumb.gif. I was hoping to use the 3/4 ton rear driveshaft and just shorten it rather than conversion u joints on the 1/2 ton driveshaft. I looked under the truck and it has a 2 piece rear driveshaft with a carrier bearing. Is there a way for me to make this shaft work on my 79 K5?
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Take it to a driveline shop and have them cut it down and retube it. They can reuse the yokes that way.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    The donor truck from my 14FF was a 79 C-30 SRW. I took the two piece driveshaft as well hoping to somehow use it but the factory tube diameter was an unusual (and small) size so after much consideration and shopping I finally went with a new d-shaft from Jesse at HAD. I got the basic non CV, .134 wall, 3" tube, 6" slip, 1350 non greaseable Spicer u joints for $309.00......the greaseable ujoints are less expensive I think.......This upgraded my tube diameter by alot and got me all new parts. Ive been very pleased with the product and service. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif
  4. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Yeah. I noticed the tube on the 3/4 ton shaft was longer than the one on my 1/2 ton. I'm starting to maybe think of making my own square tube driveshaft since it will be a trail only rig.
  5. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Not a bad idea, strong and inexpensive. /forums/images/graemlins/thumb.gif
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I did this with a two-piece shaft from a Suburban. I just got rid of the carrier bearing and didn't even take the other half of the shaft. If was useful for the 1350 weld yoke, slip yoke and stub shaft, which can be reused with standard 3" tube. This was an 89 or 90. I don't know about he older models.
