3/4 ton front and 15's
Discussion in 'The Garage' started by MTBLAZER89, Jun 24, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    3/4 ton front and 15\'s
    /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gifThey don't fit /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif.It's an 8 lug 10 bolt. Any body have pics of their grinding jobs. I want to see where and how much I have to grind. Or just a good description will do. Thanks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  3. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    Re: 3/4 ton front and 15\'s
    The 3/4 ton's are different than the d60's. You end up grinding more on the backing plates than on the calipers themselves. If I remeber right the two really high spots are just below the caliper and on the little bulge on the top not far from the caliper. I had to grind mine a lot thinner than I would have liked on the top, but I have locked up my 35" Mud-Terrains since then with no problems. So basicly, take it slow, and remove as little as possible, and you should be OK. Good luck. /forums/images/graemlins/thumb.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    or you COULD get your ½ton backing plates and callipers but it might not stop as well
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I already tried putting the half ton sruff back on. The 3/4 ton rotors are too big. The calipers won't fit then.
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    It all depends on the backspacing of your rim. I banged down the backing plates and only ground down the caliper, that's after i found out it would be easier that way. the other side wasn't so lucky.
    ARQ.
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well it's done. I bolted the rims on drove it 20 feet tooke the rims back off, and ground down where it was rubbing. Everything spins free now and I learned something new /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif. I also took pics for later if anybody needs an example.
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'd like pics. Thanks.
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
