3/4 ton MC and Booster on K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Beast, Feb 27, 2001.
  1. Beast
    Beast Registered Member
    Oct 26, 2000
    27
    Southern California
    My stock (1/2 Ton) master cylinder and power brake booster are both leaking (fluid, vacume) and I had a set from a 3/4 ton pickup that I was considering putting on. It looks like a direct bolt up but I wanted to make sure that the 3/4 ton unit will not over pressure anything. I was hoping it would just give me better pedal feel and a little more force to the brakes. I've got 33's and it just feels like I have to push too hard sometimes to make the truck stop.
  2. fastzilla
    fastzilla Registered Member
    Feb 12, 2001
    20
    Dallas, TX
    Chances are they are the same... I've found that all the Chevys I've been in that lots of pedal effort is required. Except with the hydraulic assist brakes on the diesels.... I'd bolt it up and give it a try. You can buy a proportioning valve pretty cheap if the f/r balance if off.
    Eddie
