3/4 ton question
Discussion in 'The Garage' started by chevy wrangler, Jun 22, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    what is the biggest tire i could run with my stock 1974 K-20 axles??? the rear is a 14FF and the front is a dana44. any info will help. thanx!!!
  2. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    im not sure about yours but im running
    32s on a stock 89' toyota
    33s on a 98' chevy tahoe
    and 33s on a 86' chevy 1500 longbed
    and so far the only major truble has been with the tahoe i blew the tranny and the rearend at the same time and the worst part was that i was on pavement in the midle of town
    hope that helps
  3. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    depends on your lift and how much you cut off... you could probably safely run 39.5's but that is probably pushing it. Not knowing your gear ratio. so on and so forth. if you do a search this topic has been talked about hundreds of times.
  4. pin_it_to_win_it
    Jun 21, 2006
    94
    i used to run 38.5" swampers on my 3/4 ton saburban with a 10" lift and 4.10gears. the only problems i had with that was minor fender rubing in the front and i blew a tranny. sorry to say the burban was wrecked.
  5. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    thanxz. i'll probley go with an 8" lift and some 37s. how do u blow the trans and rear axle @ the same time???
  6. pin_it_to_win_it
    Jun 21, 2006
    94
    lol i have no clue.:confused: ... i sort of jumped the truck on a curb and when i landed it all just snaped lots of loud noises at the same time.
  7. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    WOW!!!!LMAO, your a GOD!!!
