3/4 ton rear springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, May 17, 2002.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    In going to get the front diff out of a 78 3/4 ton and was wondering if the rear springs will bolt right in from the truck on to my 85 blazer.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    1/2 and 3/4 ton are the same distance apart so you should be ok there but i think the length is different, i don't even know how long my 3/4ton rear springs are. /forums/images/icons/blush.gif
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    early 3/4 tons springs came 52" or 56" i forget when they changed. Im thinkin it was 75-76ish. After that they were 56" and half ton were 52" so unless they are 52" i am almost positive they wont fit
  4. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I used the springs from a '78 3/4 ton 2wd on my 1/2 ton Sub. They were 56" so I had to move the rear spring hanger bracket back 4".
  5. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i know 74's 3/4 tons had 52" i got a set in my blazer now.i think the 56" ones were on the high gvw ones
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    The springs from my 77 K20 went right into my 77 K10. (if that helps you any)..... I think it will work fine
    mike
