3/4 ton Rearend question
Discussion in 'The Garage' started by gotchevys?, Apr 8, 2006.
  1. gotchevys?
    gotchevys? Registered Member
    Aug 20, 2005
    36
    Harrisonburg VA
    Hey guys, I need a little info. Can you give me some information on this rearend. I know ive seen one on here before but can't remember where it was. The rearend is original and is in a 71 3/4 chevy 4x4. Also I need a set of 2 inch brake drums for it. The owner of the truck has had no luck finding them. Suposedly they made 2inch and 2 5/16 inch drums for these but the 2 inch was only used in 71. This is the info i got from the owner. If you can let me know where I can get a set it would be great thanks.:burb: :usaflag:
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    It's an Eaton rear, IIRC HO52?? The only difference is in the brakes. If your having a hard time finding drums, then why not put discs on it?? Probly be cheaper that way too, cause when you do find drums, inless used, they will be expensive....
  3. gotchevys?
    Aug 20, 2005
    36
    Harrisonburg VA
    The customer has not had any luck finding new drums so we are hoping to find a good used set or at least 1 because only one of his is bad. What can you tell me about the eaton rearend. What trucks did they put them in and what are the pros and cons of them?:burb: :usaflag:
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Are the shoes 12x2? I can get them through Advance no prob it appears. just go to partsamerica.com and enter the year/make/model then search brake shoes...it will walk you through it.
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    lots of the 14ff parts swap on to them. you might try upgrading to the 14 bolt brakes. i have seen it done on some parts. i know a friend used the 14ff ebrake cables on his . direct bolt on.
  6. gotchevys?
    Aug 20, 2005
    36
    Harrisonburg VA
    red neck dude i need drums not shoes
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    So far I've only seen the 11-5/32" and 13" drums on the Eaton. The '72 D60 rear I had used the 12x2" drums.
