3/4 ton springs for a 1/2 ton?
Discussion in 'The Garage' started by 82K5_6.5L, Jun 20, 2005.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    please please tell me that 3/4 ton front springs will fit on a 1/2 ton?!!??? it was my bday friday, and my dad wanted to get me new front springs cuz mine are really sagging. well since its a diesel, he wanted something beefier. so what the paper says its "Chevy/GMC 1973-87 truck and suburban 3/4 ton 4x4 4" Heavy Duty Suspension lift kit w/ rear blocks" They are from www.SuspensionConnection.com so the springs are Tuff Country EZ-Rides. but since my K5 is a 1/2 ton, will they fit? i dont see why they wouldnt? :confused:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes they will, same part numbers on all springs including 1 ton. :thumb:
  3. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    thank you thank you!! i was kinda worried they wouldnt fit. do u think there will be any difference being a 3/4 ton spring ex. maybe more "heavy duty" and wont sag as quick? "Heavy Duty leaf springs recommended for vehicles with big block engines or snow plows" <-from the website
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    they have an extra leaf and have a slightly higher spring rate than the standard ones, so no they wont sag nearly as quickly
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A 3/4 ton lift kit will have a larger u-bolt for the rear to work with a 14 bolt axle. If you have a 10 bolt or 12 bolt rear axle you may need new u-bolts.
  6. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    im not going to be using the rear blocks. my dad is gonna toss them on his 81 3/4ton.. so it'll work out for the both of us.. since he has the 14sf..
    thx guys
