3/4 ton springs in a 1/2 ton
Discussion in 'The Garage' started by kerwinq, Feb 29, 2004.
  1. kerwinq
    kerwinq Registered Member
    Jan 25, 2004
    20
    Boise, Id
    I am thinking about putting 3/4 ton springs in my 75 1/2 ton 4x4, I was told this will raise the truck about 2 inches but will give a rougher ride. Has anyone done this? What kind of ride can I expect? Or is there a better and easier way or raising the truck about 2 inches?
    Thanks for the help, Kerwin
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    you will not like the ride. My buddy did this and he took them out after a week. when he went over a spped bump it was like driving off a 18" curb. hard hit and no give from the thick heavy springs.
    I hope this helps.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    they WILL hurt you when you drive it.. i suggest if you like your kidneys, you invest in a nice lift kit instead of a 3/4ton spring swap..
  4. kerwinq
    Jan 25, 2004
    20
    Boise, Id
    Would the ride be better if only the front was done and I used blocks in the rear?
  5. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    It'll be a little stiff in the front, but that doesn't matter. I drive my 72 K20, which is 3/4 ton, really a 1 ton in the rear, and it's a tad hard on the kidneys, but it's not too bad. I say run what you brung!
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    just amke sure you buy the right length 3/4 ton pack, they came in 52 and 56 inch lengths.
    i would swap for a 3/4 ton pack if you are not concerned with losing some flex. and remember, it is a truck, it is supose to ride like a truck. if you want a silky smooth ride, buy a buick
