3/4 ton springs on a K5 ?.
Discussion in 'The Garage' started by blazerguy 90, Dec 16, 2004.
  1. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    Will 3/4 ton springs from a suburban bolt on to my 90 K5 in place of the stock springs ?, and will they add any lift ?, the stock springs on my blazer are sagging a little and im looking for a spring that will bolt on in place of the stock springs, if the 3/4 ton springs won`t work, then I will just buy new springs.
  2. blazerguy 90
    Nov 12, 2004
    126
    EL Sobrante, CA
  3. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    This is from ORD's site in refernce to rear lift springs:
    I would think they would make a much stiffer ride. I would also suspect there would be some "lift" resulting from the springs. I suppose you could maybe pull a leaf or two out.
    If it were me, I would order some Tuff Country springs from ORD. Or you could get a 1" zero rate if your just looking to level the truck.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they will bolt up if they are the same length, you can get either 52" or 56" in the 3/4 ton burbs/trucks. they will not give you any lift maybe 1/4-1/2" if anything because they may have an extra leaf or 2.
    you have the 52" springs in there now
