3/4 ton swap-Let's try this again!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5_73, Feb 8, 2001.
  1. K5_73
    K5_73 Registered Member
    Feb 5, 2001
    53
    Wichita, Kansas
    3/4 ton swap-Let\'s try this again!
    I bought my 73K5 the other day, and I've been drooling about upgrading it. I have a 74 3/4 ton 4x4, with an NP203, 14bolt and Dana 44HD w/ new Warn premium hubs, and the old Jackman style 8 lug wheels. I would like to swap the diffs into my Blazer, and have a few questions about it. I'm pretty sure the 44HD will go right in there w/out any mods, and that the rear driveshaft yoke will need to be modded for the 14bolt. I was wondering if the rear brake lines will still reach, and if the brake booster and master cyl will need swapped in as well. Also I've heard that I may be lucky regarding the spring perches, as most people say that they should be the same. Can anyone let me know anything I've left out, and what I'm wrong about? Any info is appreciated. Thx. Oh, and for a few laughs, check out my page at k5-73.coloradok5.com
    Stupid hurts
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Re: 3/4 ton swap-Let\'s try this again!
    Everything will bolt right up, with the exception of the rear driveshaft.
    ken
  3. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Well, it should bolt right up.. You can use your rear driveshaft as well. However, you need a special U-joint. I found a brand new one in the glove box of my truck a few weeks back. I plan on doing a 3/4 ton swap with it. However, it would probably be best I go with a larger yoke shaft later on.
    I feel that the "trick" joint would probably be a weak spot in my drivetain.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    It's all fun 'n games, till someone gets stuck.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I put axles from a '74 3/4-ton under my '75 K5. It's a bolt on task. Did the whole swap, by myself, in the parking lot at an apartment complex. That 14-bolt FF rear is one HEAVY mutha!!! Having a couple friends around to help move that beast will make life much easier for you.
    The only difference is the u-joint. The yoke on the 3/4-ton takes a larger bearing cap. You can buy crossover u-joints that have 2 cap sizes. Half of it fits your driveshaft and the other half fits the 3/4-ton yoke.
    I even put the 1/2-ton axles under the 3/4-ton and then sold that truck. I actually ended up getting paid to convert to the 3/4-ton axles on my K5! [​IMG]
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    See how easy it sounds. You know you want to do it. All the cool kids are.
    '73 K5
    Chevy good...Ford bad
  6. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    Ok, I'm convinced. So Klunky, you up for it? Sounds like lot's 'O beer drinking, and power tools in our future. And if I could put my old diffs under my truck and sell it as a rolling chassis for a few bucks, that would rule! Laterz
    Stupid hurts
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    How 'bout a 14 bolt from an '85 K20 into an '82 K5. Will the parking brake hook up also and everything else ( i know 'bout the u-joint)
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    More likely this 14 bolt from an 85 K20 is the semi-floater. The parking brake WILL NOT hook up, since the 82 and older brake cables are equal length. 83 and up have a longer passenger side cable which runs over the pinion/yoke to the driver side to meet with the driver side cable and run under the frame rail. The holes where the cables go into the backing plates are both different also.
