3/4 ton swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by evil bastard, Jul 9, 2000.
  1. evil bastard
    evil bastard Registered Member
    Mar 14, 2000
    18
    central wa state(yaakima valley)
    hey all, just read the article on the main page but im still wondering.....my 74 has a d44 front/12bolt rear. will a 3/4 ton 8 lug d44 bolt right in? i was wondering about caliper sizes and brake fittings(id like to use my ss brake hoses) as for the rear......is everything compatible, such as brake hose fitting, spring perches, etc? will i need a different brake proportioning valve for the bigger drums? this swap wont happen for a while but id like to know all i can ahead of time.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Both axels will bolt right in. The calipers are different so you will have to change the brake lines in front. the rear will be fine, EXCEPT for the E-Brake cable you will have to get a backing plate off of a 14sf or get the E-Brake lines from a 3/4 ton. I also wondered about the breaking thing, the Power booster is no diferent between a 1/2 and a 3/4 ton truck and you should have no probles with the proportioning valve. It is a match made in heaven!!
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    for optimum braking, you should use the 3/4 ton master cyl. the wheel cylinders are larger on the rear and require more fluid to operate.
    your right. I don't understand the jeep thing!
