3/4 ton VS 1 ton 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudGorilla, Jan 14, 2001.
  1. MudGorilla
    MudGorilla Registered Member
    Jan 14, 2001
    33
    Oregon, USA
    Are there any differences between a 3/4 ton and 1 ton 14 bolt? I saw in another post the the 1 tons have bigger brakes and the spring perches are father apart.
  2. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    So far I have found that everything is in the wrong place!(perches, shock mounts, backing plates although they will work) As far as the guts, I think they are all the same.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  3. Single axle 1 tons are the same width,the perches and shock mounts are in diff locations.A 3/4 ton is a direct bolt in for a 1/2 ton rear.The break size depends on gvr of the truck they were in.
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Do you know the overall length of a 3/4 or 1 ton single wheel axle?
    Not FROM the people
