3/4 ton w/ 14BFF or 14BSF
Discussion in '1936-Present Suburban' started by mini_mull, Mar 31, 2005.
  1. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Did 3/4 ton suburbans come with 14BFF or 14BSF?
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    s/f:frown1:
    as far as i know maybe some older ones had ff, but pritty sure it was only S/f
  3. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    What components were beefier on the 3/4tons than the 1/2 tons? (frame, springs, others, ?)
  4. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah springs, rear axle, tranny(400) brakes,
    the 3/4 tons also had this weird adjusting valve atached to the rear diff, so the lower the assend say (more wieght) it would adjust the brakeing some how, mine and many other peoples are bypast because i guess it is easyer then fixing it when it gose bad.
    and they sit a little hight and that looks better to me
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    the 3/4 2wd came with the 14ff
  6. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    OK, so if I want my end result to be a 4x4 with 700R4 and a 14BFF I'm better off starting with a 1/2 ton, correct? BTW, were diesels only offered in the 3/4ton 4x4s or 1/2 ton 4x4s too?
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    The 1/2 tons came with the 700r4 and the th400 came in the 3/4 tons I'm not sure about the diesels.
  8. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    I HAVE SEEN 1/2 AND 3/4 TON DIESELS,
    and the 700 is also in 3/4 tons not sure about 4x4 but my 90 3/4 2wd had it.
  9. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    My 90 3/4 ton 4x4 burb came with a 350,sm465,np241 with 10b front & 14sf rear
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    All depends on the year of burb. My dads 77 3/4ton has a stock 14FF. I think the SF's started showing up on burbs in the mid to late 80's.
  11. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    3/4 ton suburbans dont have the brake valve, only pickups do. My burb is a 91 V2500 and it was 350/4L80E/NP241/10 bolt/14 bolt SF. Stock.
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If your talking about that THING mounted to the top side of the diff, then that wrong...my neighbors 3/4ton burb (1984)has one on it and its stock.
  13. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    My neighbor has a 1995 3/4 ton Suburban with IFS and a 14bff.
  14. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    as does mine (or did)
    and so does sled dogs i belive actualy his was removed too.
    yours doesent most likely because by then they had RWAL and wouldent have used it (maybe)
  15. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    The newer Subs with big blocks came with ff, the Subs with smallblocks came with sf. The problem is that Suburbans didn't have bigblock engines in 4wd till 92 when the body styles changed. I have a 1990 2wd burb with a 454 and a 10.5sf axle.
