3/4t axles same as 1/2t???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Jun 6, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Does a 3/4 ton front 10 bolt or dana 44 have the same axles as a K5 1/2 ton d44? Use the same u-joints?
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Given that it is the same year, the axles and U-joints are the same. Just the hubs, rotors and brake parts are different.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Given the same year, they may be the same as Blazer1970 said, but I know that my D44 from 1971 had 1/4 inch smaller diameter axle tubes than my 79 3/4 ton 10-bolt. The u-joint is the same. JT
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    74+ D44's use the same u-joints and axles and the pre74 axles use a smaller u-joint in the axleshaft but will still work in the 74+ if you use the complete pre74 axleshaft with the small u-joint.
    All the 10 bolts use the same axleshafts and u-joints as far as I know.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes, they all are the same !
