3/4t Caliper Grinding w/ 15" Rims
Discussion in 'The Garage' started by guido666, Oct 27, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I see everyone talking about having to grind calipers on 3/4 ton 10-bolt axles when using 15" rims. I have 15x12 rims with 4.25" backspacing, and they seem to fit. They rub the caliper support plate (or whatever you call it, that bolts behind the spindle and the caliper hangs from) ever so slightly, but a little grinding and they clear. Am I missing something or is this ok?
  2. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I had to grind the caliper holders on my Dana 44 in order to make the 15" wheels as well. Seemed to work.
  3. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    Tighten up all of your lugs and try again. If it sounds like it rubs you clould do what I did and put a little bit of white paint on the inside of the rim and let it free spin then take it off and see where it rubbed. It was a huge PITA for me, I had to grind alllllllooooootttttt. Glad to hear it was a little easier for you :waytogo:
  4. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    I went with a 15x8 8 hole with 2.75" backspacing, no caliper grinding whatsoever..
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Thanks, I think I'll try that paint trick.
  6. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    make sure you got a fresh set of brake pads in there also. it make the caliper stick out further and as was posted torque down the lug nuts. i bet you will find you need to grind.
