3.73 or 4.11 gears???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Sep 23, 2002.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    Right now I have 32" BFG's, i'll probably get 33x12.5 with a 2.5" lift. I think i'm running 3.08's now, it's stock. So should I move to 3.73 or 4.11's? It's my daily driver, oh and will I notice a big increase in acceleration?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'd go 3.73 if it was me
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Go with the 4.11's, and yes, acceleration will be alot different than the 3.08's.
    John
  4. anatomiczero
    Jun 26, 2001
    418
    Washington
    Will 4.11's be good on the freeway (65-85mph) I'm thinking the rpm's will be a little higher(obvious) so it would use a little more gas there, but I wouldn't have to step on the gas as much to get it up to speed so it will balance out. What's an estimate $$ to have 4.11's installed?
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    not sure about install but i'd definetly go with 4.11s. cuz 33s will only last so long, after them you will want 35 and 3.73s with 35 would suck ( i know i run 3.73s with 36 right now)
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I would say 4.10s so then later when you go bigger tires again it would be already suited for them. Trust me, you will always go bigger /forums/images/icons/smile.gif
    Isntall isn't the hardest thing but is very very time consuming since you will put together then tear apart many times before getting set correctly.
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have 3.73's and 33's. I like it,but I have a 700r4 also. With your set-up I would get 4.11's. /forums/images/icons/grin.gif
  8. anatomiczero
    Jun 26, 2001
    418
    Washington
    Cool, I'll go with the 4.11's
  9. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    3.73 if you have a manual or three speed auto. 4.11 if you have Overdrive.
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Go with 4.11's. It'll be well worth it.
  11. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    There is not much differnce between the two. I had 3.73's before, but when I got my 14BFF it had 4.10's, so I regeared the front. There is not much (seat of your pants) differnce between them that I can feel. But you will be able to tell a big improvement over the 3.08's /forums/images/icons/cool.gif .
