3.73 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Feb 18, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i have both a D44 and a 14FF that have 3.73 in them. i knowthat the carrier break for the D44 is 3.73 and for the 14FF is 4.11. if i get new carriers on the higher side i can put 5.13's in right?
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    In a word... Yes.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i got me wiggn out on the in a word part....
    Grant
  4. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    My mamma told me there's no such thing as a stupid question...so here goes....
    Is it also the case that if you have a factory 3.73 D44, 4.56 will work with the same carrier?
    Im confused by SeventyFour's "...get new carriers on the higher side" and the cryptic "In a word...."???
    Can someone explain the "carrier break" concept a bit more?
    Matthew Meyer
    matthewm@inhollywood.com
    '71 Ochre K5 - 4" Lift 35"s
    ZZ4 350 - 700R
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    in general you will need carriers for both axles to run the 5.13's
    I think there is a "thick" gear set availible to run the lower gears in the higher case.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The carrier break for D44 is 2.72 to 3.73 and 3.92 to 5.89
    The carrier break for 14BFF is 3.42 to 4.10 and 4.56 to 5.13
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, they make thick gears for the 14 bolt. i think they make them for the 44 too, but i am buying a detroit for thr front anyway so i might as well get the carrier i need and spend less on the gears.
    Grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  8. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    As I understand it...
    As the gears get lower (or numerically higher), the pinion gets progressively smaller. At a point, based more on ring gear size associated with the pinion size (that is why it is different for axles with different ring gears), the carrier itself is recommended to be changed. The ring gear mounts to the carrier and the carrier bolts into the diff housing. The different carrier positions the ring gear more appropriately for the smaller pinion. This keeps from a significant shifting of the carrier which may not even be possible. "Thick" gears can also be used. These gears have a thicker ring gear. the thicker ring gear counters the modified carrier position. I do not believe there are any downsides to using thicker gear sets. The only upside is that it keeps you from having to change the carrier.
    Hope this helps clear up the carrier break. If I have missed something or am not correct on something, someone please correct me. I will never know if I am wrong unless someone points it out to me.
    Brian
