3.73s in a cucv
Discussion in '1982-Present GM Diesel' started by 84CUCV, May 14, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I was wondering how 3.73s would be compared to the 4.56. I going to swap the 1 ton for the 3/4 ton rears and sell the truck. 3/4 ton rears came from a p/u so they should bolt right up right??? What about the drive shafts? thanks mike
  2. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Anyone??
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    It seems to me 3.73 would work well to lower the rpm's to a good range for the 6.2. The 3/4 ton's should bolt in. The only difference is the Ubolts for the 60 will not work on the 44/10 bolt. Ujoints should be the same and driveshaft length close.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK will i be able to do about 65 with not to much rpm? thanks mike
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What tire size are you running? /forums/images/graemlins/thinking.gif
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    the 3/4 ton rear will NOT bolt in , the spring pads are farther apart.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    For now stock tiers. Down the road 36. I got them for 200 bucks complete so i figure i can go wrong.
    mike
  8. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Oops! Yup, forgot about that problem. /forums/images/graemlins/doah.gif
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    yikes, stock tires, 3.73's no OD. That will move, but it will be some high RPMS. around 3000ish I would guess.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    How do you figure 3k?? From what little i know, i figuerd 25-2600.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Anyo f you have calipers for a 3/4 ton ten bolt? Didnt even see they were not there till i got them home. thanks
  12. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Can i use 1/2 ton caliper on the 3/4 ton front?? thanks for the replys.
  14. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    1/2 ton calipers and 3/4 ton calipers are the same thing...so yes.
    Rene
  15. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I thoght they would be stronger calipers or something like that. thanks
  16. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Ive got 3.73's in my K5, with 33's. She moves right along. Wont win any drag races, but thats not my thing.
  17. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks guys i got calipers. mike
  18. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    They are not stronger by them selves.
    The fact that the rotor is bigger, and the mount for the caliper is further from the center gives it more leverage, that is how it's stronger.
    As long as you have everything else from a 3/4ton axle the calipers are interchangeable.
  19. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks /forums/images/graemlins/waytogo.gif
