3.73's or 4.10's
Discussion in 'The Garage' started by steve_kibbe, Oct 27, 2006.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'm going to put a 14bsf in my 88 K5 daily driver.
    I run no lift, other than a 1" zero rate in the back, 350 tbi with a 700r4...33's at for the street and 33" tsl's on the trail.
    I do a good bit of towing, either a flat trailer with landscape blocks to tractors and a 12' dump trailer with construction dibre and gravel.
    Future plans for my blazer include a slow build, but keeping the 33's for a while with no lift.
    What gears would work better 3.73's or 4.10's.
    Btw, I'm wanting to keep the 6 lug for now, thats why I'm not going 14bff.
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Well, since you`re going to be towing a good amount of weight and often, the 4.10`s wont hurt, but i think 3.73s could get the job done as well.....so i would just go with the 4.10`s, seeing as your also running 33s
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I run both in two different vehicles. If you're going to be doing quite a bit of towing, I'd stick with the 4.10 gears. If you'll be doing mainly highway driving with just occasional towing, I'd go with the 3.73 gears.
  4. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I have thought about 4.56's, but I don't know if thats too much.
    I'll have to play with the ratio calculator some more.
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i think the 4.56`s will be over kill....i pulled a 6x10 trailer with my blazer when i first got my license, i was helping out a friend who was getting his eagle scout, so we pulled a bunch of fire wood up to a shelter that had a giant fireplace that did very well to heat the place in the winter, pull it up i would say a 30 degree incline for a good 1/2 mile, and she had no problem, and thats with 3.73s and 33s, i think 4.10s would`ve been ideal...
  6. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Not too sure about 4.56, 700r4, and 33" tires on the highway. I have 4.56 with 35" tires in my CUCV and it still screams at 65 MPH, but I don't have overdrive. I would guess that the 4.10 would be the best of both worlds. That rpm calculator can be your best friend for this type of decision.
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Just to give you an idea of what I pull...
    Last week my total weight was 14800#:D
  8. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Is that with the GMC or the K5?
  9. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Thats with the K5:doah:
  10. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I tow a 28 ft. travel trailer w/ my '90 K5 w/ 33's and 3.73's. I've thought about going w/ 4.10's, but the 3.73's seem to do ok and I am afraid of what 4.10's would do to my mileage. I have not ruled it out but I don't want to get minimal pulling power while burning alot more gas. I don't know that that would be the case, that's just my fear.
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    For those of you who have been around long enough to remember Zakk, I know what he'd say at a time like this:
    "5.13s are the answer to all questions....."
    :D
  12. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :D Thanks Greg:D
    I haven't thought about 5.13's....
  13. goldwing2000
    goldwing2000 Guest
    Another vote for 4.10.
    The extra power is ideal for towing, it will reduce the load on your poor little 700R4 and the overdrive will take care of hwy rpm isses.
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    First of all, there really isn't a huge difference between 3.73 and 4.10. With that said I really don't think that 4.10's would make a huge difference in gas consumption then 3.73 would.....I would guess you would have a small amount of extra pulling power and use a very small amount of extra gas. It's not like going to 4.10's would lose you 3 mpg or anything.
    4.56's would not be bad either. Keep in mind that the 700r4 has a 0.70:1 overdrive ratio, so 4.56 gears would be the same as 3.20 gears in a truck without OD.
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    After having pulled 33's with 3.08's , then pulling 33's with 3.73's . They worked , and I advocated them .
    But after going to 35's they kinda left me wanting more gear .
    I went 4.56 just recently , and you can't pay me enough to ever go back . And seeing what my tach reads , I COULD HAVE went 4.56 when I had the 33's <---------- :thumb:
  16. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    I recently pulled a 2 door 67 plymouth fury III on a 2000lb trailer with my Jimmy. I have 4.10s and 35's it was fine on flat level ground in 3rd gear but hills were definately a chore. I say go with the 4.10's for sure. If your in a really hilly area think about 4.56's.
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i used to run 35s with 3.73s and 700r4 and i thought it had good power, but i wasnt towing. what tranny does it have? if its 700r4 id definitely get 4.10's or maybe even 4.56s. originally i was planning on 5.13s and 35's until the go bigger bug hit me. with the overdrive, 4.56s would be sweet!
  18. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    It has a 700r4, as stated in the first post:D
  19. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    are you going to stick with 33 for ever?
    I would go for the 4.56's,
    That way you have the option of going to 35's latter
  20. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine came stock with 4.10 which is great for towing and did well with my 35's. 350/400/241
