3/8 or 1/4??
Discussion in 'The Garage' started by dleroy43, Sep 9, 2006.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I am figuring which parts to order for hydro assist, hoses/ fittings/ taps, and I am still confused of what size to use. If the ram uses -6 fitting then I should use 3/8 hose and a 3/8 tap into the gearbox correct? I found some that used 1/4 hose and/or taps as well. Does it really matter what size?
    :burb:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You want to use 1/4" NTP tap into the gear box and use a -6 fitting and 3/8" hoses. The -6 has an inside diameter of 3/8" roughly and so does the inside of a 1/4" NPT fitting.
  3. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    Thanks :D
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is backwards. A 1/4" (2/8") fitting is smaller than 3/8" therefore the inside of a 1/4" fitting cannot be close to 3/8.
    For my ram I have -6 fittings and will be drilling and tapping to 3/8 NPT. I actually am only tapping the top cap as I purchased the end cap from JKWOffroad.
    Ira
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well, i just went out and measured a fitting and 1/4" NPT fitting is .300" ID so .050" larger than 1/4" but .073 smaller than 3/8". Just remember that if you try to tap your box for 3/8" NPT you will probably be looking for another box as 1/4" NPT is VERY close to being too large if you tap in the common areas.
  6. sandawgk5
    Oct 28, 2003
    6,881
    I am tapping the top cap not the box itself. I also have a new aluminum end cap that is tapped for 3/8 already:D .
    Ira
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The end cap will be fine but i would watch out tapping the top cap as i've read horror stories about the top cap exploding from being tapped there since there isn't much material in that area and the cap is fairly thin there, especially if you do the pump mods.
  8. sandawgk5
    Oct 28, 2003
    6,881
    The top cap is over 1/4" thick in the thin spot. The problems I have heard is the people using the factory end cap and tapping that as it is basically sheet metal.:D If I do break a top cap I will figure a new way to do it.
    Ira
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    One of the vendors here posted a pic of a billet top cover they were making. Along with it was a pic of the end cap they were also making.
    Another point on the plumbing. Do not use the forged, tight 90* hose ends. Use the tube type swept 90*'s.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    3/8 is huge for that purpose. I would recheck that. Alot of people mistake the OD to be the size when it is really the inner diameter of the fitting/line.
    A 3/8 NPT tap reqires you to drill a hole bigger than 1/2"
  11. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    but I am tapping the box, not the caps :deal: . I could see how 3/8 would be too big for the box. So for the lines, 3/8 then?
  12. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Almost every kit you see uses 3/8 lines with -6 AN fittings and 1/4NPT holes in the box, caps, side or what ever.
    If you tap to 3/8NPT you will imidiately put a reducer in the system to step down to the hoses or the ram.
  13. sandawgk5
    Oct 28, 2003
    6,881
    Not sure if I am understanding the concern but here is the cap I am using. It is tapped to 3/8 NPT and I am running 3/8NPT to -6 fittings to my hoses. My ram has -6 male fittings on it.
    Ira
