3' Body lift(How hard) Diesel
Discussion in 'The Garage' started by dallassnowman, Feb 25, 2005.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Looking at doing a 3 inch body lift on my 82 6.2 diesel Blazer.
    1. Is it hard??
    2. Does it involve more because its a diesel??
    3. Can I do it in a weekend??
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    1. Depends on how rusted your bodymount bolts are.
    2. Maybe. The oil & trans cooler lines could be difficult. The brake lines from the M/C should have coils in them for flex, they should allow the necessary movement. You may need to modify (extend) trans & T-case shift linkages.
    3. See #1
  3. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Whats involved in extending the linkages?
  4. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    well i have no experience with disels but on my blazer it really wasant that difficult
    it took me about 8 hours of work but i ran into bushing problems and i had to order pieces.
    Fanshroud - easy no big deal
    WIres lines ect - no problems
    gas tank - no problems.
    linkage for steering colum- easy cut and weld.
    4wd linkge, mine wasant effected.
    steering shaft - dill and it extends
    steering colum - make sure to follow instructions about loosening so you can do nessicary adjustments.
    ONE THING TO MAKE SURE OF!!! - DO ONE SIDE AT A TIME LIKE THE LIFT SAYS. YOU MAY THINK, HEY I GOTTA HYDROLIC LIFT LOOK AT ME IM LIFTING IT ALL AT THE SAME TIME!!! WELL THIS IS WHATI DID AND THE WHOLE CHASIS SHIFTED AND I WASTED PROBABLY 4-5 HOURS LINEING IT UP AGAIN.
  5. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    cool thanks..looks like I may wait till it gets warmer..I hate to rush.
  6. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    dont forget to detatch or cut the restrictors in the tailgate. they are strong litttle buggars and actually held up the rear end of my blazer.
  7. Luehrs1
    Luehrs1 Registered Member
    Feb 5, 2005
    48
    Jacksonville
    I have a '89 Blazer and I'm going to start my 3" body lift this weekend and i had a couple questions. Is there going to be a problem with the trans cooler lines? Also is it necesary to drop the gas tank? Any help is appreciated.
    Patrick
