3" body lift installation
Discussion in 'The Garage' started by Luehrs1, Mar 24, 2005.
  1. Luehrs1
    Luehrs1 Registered Member
    Feb 5, 2005
    48
    Jacksonville
    Ok, quick question I'm about to install a 3" body lift on my '89 Blazer. I'm tryin to figure out if i have to modify my trans cooler lines. The body lift says that the radiator moves up with the body and the trans cooler lines run underneath a brace on the frame I think. Ill take a pic and put it up so anybody with any info can understand a little better. Also is it necessary to drop the gas tank to do this? Any help is appreciated.
    Patrick
  2. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    You can "fudge" a lot of that stuff by just unbolting the last couple clamps that secure hardlines to the frame.....you may need to do that same thing for the lines coming off the master cylinder too.
    The main thing is to just look really carefully for anything that connects between the body and frame (hint: if you have an automatic, the gear selector will probably need to be lengthened) The bumpers may need to be removed to get the body lifted (I'm not sure how much they overhang the body on an '89 if at all)
    Mainly, the trick is to just lift slowly and have someone watching for anything you forgot to loosen or remove. Don't FORCE it if you feel resistance....look for the source of the problem before you damage something and make the project a lot longer..... :crazy:
  3. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    Pics
    Ok i took a couple pics of what i hope will be my only problem. I think that when the lift goes on i will be able to re-route these over the top of the bar. What do you guys think?
  4. offroadnut
    offroadnut 1/2 ton status
    Jun 5, 2003
    116
    Indianapolis, Indiana
    also don't forget the fan housing... it is mounted to the radiator and the fan stays with the motor. when you lift the body the fans will be pressed against the fan housing at the bottom.
  5. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    any thing body related is going up 3" nothing from the frame if moving. so all motor stuff is staying and the fan shroud will need some mods. and the shifter or shifters and gas filler wires and possible steering . also body lifts put more stress on the rag joing to keep a good eye on that.
  6. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    But the directions said that the radiator will move up 3" with the body?
  7. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    What he's getting at is that the radiator (and fan shroud) WILL move upwards, but the fan (since it's bolted to the engine) will NOT...... Basically the fan will no longer be "centered" in the shroud, so you will need to clearance the shroud so that the fan won't hit it.
  8. Luehrs1
    Feb 5, 2005
    48
    Jacksonville
    I get that, but what im tryin to figure out is these cooling lines go into my radiator, and by moving it up 3" these lines are not going to be able to because of that cross member, so whats the best way to get around that?
  9. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Or............. you could just do what I did and not raise the core supprt. I have a 3" body lift on my cab, but I left out the front core suuport. I wanted a sloping hood for visibility in the rocks. I didn't have to worry about tranny lines, fan shrouds, or nothin'. I spent about an hour massaging the fenders & hood to eliminate any gaps. Notice how the grill & front bumper have not raised, but the cab has 3" pucks under it :grin:
  10. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    If they dont fit, cut them. Reconnect with rubber tubing and hose clamps.
