3 in body lift issues
Discussion in 'The Garage' started by gsucowboy, May 25, 2006.
  1. gsucowboy
    gsucowboy Newbie
    Mar 1, 2005
    Ga
    Ok guys, got a little problem while trying to put on a 3 in body lift on my 89 k5. Every thing was going so so (which i knew then i was bound to run into a problem), got all body bolts out out of front fine, started on back and problems started, first set were spot welded on top in the bed, which may be standard, but was a time getting bolts out, but on the rear two the nuts are flush up against the frame at the top and getting a socket around them has not worked out for me. has anybody else ran into this problem or have a solution?
  2. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    Pull back the carpet and grind the carriage bolt head down and pull the rest out from the bottom.Worked for me!:D
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    What part of Ga are you in? I might can give ya a hand.
