3 inch blocks in rear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sanssocs2, May 10, 2001.
  1. sanssocs2
    sanssocs2 Registered Member
    May 9, 2001
    16
    Mobile, Alabama
    Where can i find 3 inch blocks for the rear? all i can fine is 2 and 4. can i run 315 buckshots with 3 inchs?
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    You could always get the 1" "add-a-leaf", which is just a block that the spring pack bolt goes through and then put a 2" block underneath it.
    OR...you could put in a 2" block and switch to a soft top
    OR...you could stack a 2" block with a 1" block, but you would probably want to drill them out and get a long allen head bolt to bolt them both together with the spring pack. If you do take your spring pack apart, be sure to clamp it together first with C clamps.
    OR...you could get a 2" add-a-leaf and a 1" block
    OR...you could cut the top inch off a 4" block and put a new hole in it. I think it's 9/16". This would also allow you to get the exact taper you want, but would be a PITA.
    But sorry, I don't know of anyone selling a 3" block.
    <font color=green>"Do not replace belt while engine is running" --Warning on a Kelly Srpingfield package</font color=green>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Nothing against Blue85, but never stack blocks.
    You could cut down a 4" block like he said, or if you have the sagging rear syndrome, the 4" block may level you out.
    Or, what about a 1" block and a 2.5" ORD shackle flip? :)
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    yes, NEVER stack blocks
    ADV Auto has the 3in blocks for 29$ and comes with everything u need.
    check your out, i can help u out if u need it.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    BDS has a rear block that is 3.5"...
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  6. Big_Ugly_Diesel
    Big_Ugly_Diesel Registered Member
    May 7, 2001
    60
    Fort Worth, Texas
    As with everyone else NEVER stack blocks. Rough Country also has 3in blocks and Skyjacker has 3.5in aluminum blocks but I would not recomend them. I broke both of them on my 83 Blazer.
