3 inch body lift questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jun 21, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I've got the 1" ORD body lift right now and still rub with trimmed fenders. I have never been a big fan of body lifts, but I believe I am about to change my mind. It would give me more clearance without having to do more trimming and without impacting driveline angles. It would also give me more clearance up front for my under-radiator-support winch mounting location.
    What brand is the best? I know I will have to extend the shift rod, does the kit come with soemthing for this? Will i have to weld something (not a welder) or can I just bolt something on? How will the impact to my tcase shifter be impacted?
  2. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I recommend a 2" body lift. Many things start getting in a bind with the 3" body lift. The only thing you have to do is extend the gas filler and extend the automatic tranny linkage. They give you a little rod to weld to your linkage. With a 3" you have to do lots more. I have installed two Performance Accessories 2" kits and they both worked well.
    Good luck.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    The only other thing I had to do with my 3" was to modify the hole for the t-case shifter. I had to cut a 1/2"x1/2" notch in the tranny hump so that the shift would fully engage into low-loc. Then I moved the shifter boot up, drilled new holes and screwed it down. You can't tell there is a notch in the floor, and I don't have any carpet or other type of covering. I spent about an extra 15 mins. to do that verses a 2" on I installed on my last rig.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Check the for sale boards, I have a 2" body lift and body bushing kit for sale!
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    For my friend's, all we did was weld up the shifter linkage with the 3" piece.
    To those with manuals, did you ever have to extend your clutch linkage?
  6. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I didn't even have to extend my gas filler with the 3 inch and nothing binds at all with it.
