3-inch drop steering arm
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 6.2L Jimmy, Mar 30, 2002.
  1. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi Everybody.
    Does anybody know if somebody makes a 3-inch dropped steering arm?Thanks in advance.
    Mike
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    You are probably talking about the pitman arm (the one that comes off the steering box) When you fix steering geometry from liftiong trucks, your can drop the pitman arm, raise the steering arm (the arm that connects to the top of the steering knuckle on the axle) and you can get a droped drag link (the tie-rod looking rod that connects the pitman and steering arms...If you need to correct your steering geometry, I would get a raised steering arm (avalable form www.4wheelparts.com for like $50) or if you have already added a steering arm and need additional correction, your can get the dropped pitman arm, probably also available form 4wpw for a decent price...
    Chris
