3 inch lift with 33's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Dec 2, 2001.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    3 inch lift with 33\'s
    Do yall think a 3 inch body lift with some 33's would make my 87 K-5 Blazer look that much bigger than stock or should I go with a 4 inch with 35's
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Re: 3 inch lift with 33\'s
    You should go with 4in and 35's cuz I mean... it's going to be big but after a while you're gunna get used to it and want biger and biger. So start big i guess lol. You might have to do a lil triming if you do any flexing or sharp turns
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  3. scooby
    scooby Registered Member
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    i run a 3" body, looks way bigger than stock, i wanna run 35s
    with my 3 inch body, might need to trim a little, maybe.
    i got 33s now save 3 of my 5 are flat
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You will need to trim, definitely.
    My tires rubbed with a 4" suspension and 35s.
    Tim
  5. Blazinit
    Blazinit Registered Member
    Nov 26, 2001
    29
    Minnesota
    I have a 4" suspension and BFG AT 35's. They rub under high flex and if I hit a bump when turning sharply. It definately needs to be trimmed! Other than that, the gears should not be disregarded when lifting and going to bigger tires or you might end up putting more $$$ in that was planned. Just someting to consider before beefing up the tires...
    '84 K5 Blazer 4"Rancho R/B w/Quad Diamond Back front 350/TH700r4/NP208/35" BFG AT/10 bolt F&R
    Washington, USA
