3" Lift, 37" MTR's, and a little flex
Discussion in 'The Garage' started by wayne, Jul 24, 2003.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: 3\" Lift, 37\" MTR\'s, and a little flex
    looks great /forums/images/graemlins/thumb.gif can you get better pics of the trimming you did? id like to compare it to my 2.5in lift and 38's /forums/images/graemlins/thumb.gif
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No problem, I will get them this weekend after I finish fabbing and installing the sliders. /forums/images/graemlins/thumb.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    good idea on what to do with the old tires /forums/images/graemlins/thumb.gif
  6. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    And no rubbing!!!
    How about the inside of the tire on the rear wheel tub? W/O making my track width any wider I can't seem to not rub there, at least it's a smooth spot. Or are you using shallow backspaced rims and/or spacers? TIA.
  7. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    She looks ready to take on the world; /forums/images/graemlins/thumb.gif just hope I can finish my truck in time for UCP. /forums/images/graemlins/frown.gif
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Those 35's are for daily use, we bought the 37's for play. I don't mind chewing up cheap used 35's with the Detroit on the street.
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    And no rubbing!!!
    No rubbing on the rear wheel tub as far as I can tell. I have to totally flex it to see but I think it will clear with no problems. No spacers and the rims are 17x8" with 3 3/4" backspacing.
  10. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    ME TOO!!!!!!!!!!!!!!
  11. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i'm intrested on how you acheaved this lift and how some poser shots from the side would look. I have 37 inch SSR's and i want to go with about 3 inches of lift also. Thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  12. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Achieved the lift? Just bolted the springs on. It is a Tuff Country all spring lift. The kit comew with 3" fronts and 4" rears so it sits level instead of having a saggy butt.More pics to come this weekend sometime so I will take some poser shots for you. /forums/images/graemlins/grin.gif
  13. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    I just looked at the pics again and didn't catch it the first time, but have you tried putting one of the front tire on the pile and check for clearance on the inside of the rear tire. Or the 17" rims make a huge diff, which is what I want to know. My real "?": Will 17" rims keep the tire off the wheel tub?
  14. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    It could also be dependent on what his rear end came out of, my 16x8s standard Backspace with 36x12.5 TSL Radials didn't rub on mine until I flipped overloads and did custom shock mounts. I don't think the 17s are the reason for it not rubbing, I would be willing to bet that his shock mounts are stock thus limiting uptravel.
  15. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Kind of what I figgured but you never know. He'll have to put the front up to find out either way.
  16. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I did have the front up. As a matter of fact when I put the front up the tire flipped up underneith the nerf bar. There was about 44" from the bottom of the nerf to the ground. 35 stood straight up and it was on top of the 35 laying flat. /forums/images/graemlins/grin.gif When it did that the rear tire was about a foot off the ground and I checked on the opposite side and was not even close to rubbing the inner wheel well. Yes the shocks are in the stock location for now.
  17. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
