3" or 2 1/2?
Discussion in 'The Garage' started by shaun89, Dec 16, 2006.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    im getting an exhaust put on my truck and im gonna put normal universal cats on it and 60 series race mufflers,with no equalizing pipe,and its dumping before the axle,now i want it to sound good but have enough back pressure to run healthy,and not loose any torgue so..anyone have any experience with this? o ya its a stock 350 out of an 88 caprice. thanks guys
  2. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    stock 350, i'd run 2.25 pipe and that equalizing pipe, it'll still sound good and have good back pressure.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    x2 on equalizer=more torque.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea u really need the equalizer. id run 2.5" pipes so it would be perfect even if u end up doing mods.
  5. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    I run dual 3" off the headers into an x-pipe with dual 4" coming out into 6" tips. No mufflers. enough backpressure to make the 454 happy and sounds awesome.
  6. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    A single 3" exhaust will give you the most amount of torque from a stock 350 engine.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    2.5" with an crossover pipe (an x-pipe if you can fit it) if you plan on mods, or 2.25" if you plan on leaving it stock.
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Interesting. This building upon the specs of the stock 350 as is already built for torque as opposed to high horsepower. So without the scavenging effects of the crossover, the combustion tends to be lazy, promoting torque?
  10. 88$PIT
    88$PIT Registered Member
    Sep 12, 2006
    66
    Lincoln CA
    X2...for a stock engine.
  11. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Are you running manifolds, shorty, or full length headers?
  12. dyeager535
    26,980
    back pressure doesn't equal torque, velocity does.
    It's a fine line, go with what is known to work. Too large and you lose power because the exhaust is no longer efficient, not because there isn't enough backpressure.
    Go read some exhaust articles (especially by David Vizard) if that concept is foreign.
  13. 88$PIT
    Sep 12, 2006
    66
    Lincoln CA
    Stock manifolds with smooth bend pipe to Flowmaster Y pipe, then 3" pipe to hi-flow cat and magnaflow muffler. Way better than stock setup. I would like to go with shorty headers IF I can get bolts that don't back off every three minutes!!
  14. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Look in Summit or Jegs for locking header bolts. Seems on my aluminum head 383 every month or so I need to retighten mine or I start to notice an exhaust leak and find Im missing a couple. Now Ive been reading a few engine building books and they seem to agree that you want full length headers and dual 3" pipes to make the most power, and you want the H pipe in a certain place (hot spot in exhaust). I know this is not always possible with emissions, etc. but stay with the same size pipe as your collector diameter of header. I have always gone this route running 3" pipes when using full length headers, and 2.5" when stuck with manifolds or Y into single 3". Alot of people claim big pipes hurt low end, and alot say since your header collectors are 3" after that it doesnt matter. Whatever you do youll make more power than stock, and larger pipes look sick, and usually sound better IMO. And usually if you loose low end you'll make up for it in HP, unless your building a crawler.
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
  16. 88$PIT
    Sep 12, 2006
    66
    Lincoln CA
    I used the stage 8 locking bolts before. It was a bust. The bolts would back off anyway with enough force to actually round off the special half moon cut washers and keep going! There has got to be something better.
  17. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You can buy header bolts that are drilled for lock wire.
  18. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    All those years and I never used them myself. To bad, just another hype product.:(
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    dont use paper header gaskets. use regular old exhaust manifold gaskets. tighten em once, and forget about em.
  20. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    took my engine builders advice and haven't had any leaks. bolt on the headers. then run the engine till its at operating temperature. shut it off and torque down the header bolts. Never had a leak until the other weekend when my shackle bolt hit the collector flange and tweaked everything. ran it several years like that though.
    I would run 2.25" pipe with a crossover if possible. but your question was 2.5 vs. 3. so run the 2.5" if thats the only choices.
