3" or 6"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblueblazer, Sep 12, 2001.
  1. bigblueblazer
    bigblueblazer Registered Member
    Jun 12, 2001
    21
    tampa
    3\" or 6\"
    is a 6" lift really that much better and worth the extra cost i also wanna know opinions on 2 versus 4 shock setup
    if it dont smoke,guzzle gas or cost lots to fix it aint my chevy blazer.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: 3\" or 6\"
    I would go for a 4" lift and trim the fenders to make the bigger tires fit. 35s still rub with a 6" lift, because they dont fit in the wheel well. As for shocks I would the 2 shock setup. I use to have the four shock setup up front from the factory, and it rode too stiff, so when I lifted it, I got rid of the extra two shocks.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Re: 3\" or 6\"
    Iv got 6".I like it.It just depends on what you want.I had a 4" lift.With the 4" I didnt need brake lines and the drive lines were ok.With the 6" I needed brake lines ,a front driveline spacer ,and the rear shaft is almost too short.Cost wise ,4" front springs ,shackle flip I think would be the way to go.As for dual shocks I had them on the front for years.I got tired of the harsh ride so I went to singles up front.Now I can tell I have soft ride springs up front.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: 3\" or 6\"
    what... 6" lift and tires rub... 35" tires??? um... I had a 4 inch lift and mine didnt rub??? and I wheeled the pee out of her...
    just my .02 cents
    [image]http://www.inhomenetworking.com/images/littleblue.jpg[/image]See me at <a target="_blank" href=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</a>
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Re: 3\" or 6\"
    mine rubs like crazy 35's w/ 6 inch
    3/4 ton setup
    Surfing is Life...
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: 3\" or 6\"
    reddog what springs are you using. My tuff countrys flex alot and make my tires rub. On the other hand my buddies rough country 4" lift with 35s doesnt rub. His suspension doesnt give either. The rough country springs dont articulate, they just pick tires off the groung first, thats why his doesnt rub.
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Re: 3\" or 6\"
    I ran a 4" susp. 3"body and 33s and I could chew my fenders.With my 6" susp 2"body and 35s I havent rubbed yet.
  8. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Re: 3\" or 6\"
    It's all about the saws all!!!!! Don't be afraid, i used to be. It's really not bad once you do it. You'll just keep chopping off a little more. - Doug
    Doug Krebs
