3 point seat belt to a roll cage.
Discussion in 'The Garage' started by ecameron87, Feb 16, 2006.
  1. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    My roll cage is mostly done and now I need to think about upgrading the lap belts. I did not put "X" bracing in the main hoop because I have people getting into the back seat often and this is still my daily driver. Because of this and the style of seats I have, I cannot use a 4-point type seat belt. So my goal is to attach a 3-point to the cage.
    The seats are tied into the cage and the cage is tied to the frame. You can see it here:
    http://www.wheelingarizona.com/forums/viewtopic.php?t=6377
    What are some of the ways you all are attaching your seat belts to a roll cage? Mainly I am talking about the shoulder mount. Should I weld a tab or drill a hole through the bar? I would rather not drill the hole for structural reasons. I have searched and all I have seen so far are 4-5 point harnesses and a fancy clamp that clamps to the bar (a fancy home brewed clamp.) What other ideas are out there?
    Pics would be appreciated.
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Looks like your head is going to hit the cage,ouch.....Nice job though.
    Sorry can't help with attaching your 3 point,as I run a 4 point myself.
    I attached mine to the stock mounting bolts on the floor.
  3. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    I am 6ft tall and my head is 3" from the main hoop. I think it will hit while off-roading. I better pad that area of the hoop. As for the seat belts, I don't want to tie it to the floor just in case the cage does separate from the frame, my seat belt will squash me like a bug.
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Weld on tabs and use appropriate hardware.
  5. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    Sorry to revive and old post, but does anyone know what the correct tabs are that I can weld onto the cage? It is about time to upgrade the stock lap belt.
  6. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    For the top of the lap belt I drilled a hole in the cage tube and had a bung welded in there, then secured the belt with a 1/2" diameter bolt and lock nut.
    For the floor part of the belt mechanism I had a tab welded to the cage rail that looked like the tube tab on this site (scroll down to see the tube tab). I got mine at a metal supply place in town.
    No reason why you couldn't use tabs for upper and lower. I didn't want the upper tab because it will stick out somewhere and I didn't want to bash my head into it every time I tried to get into the back. Bolting thru the tube with a bung seemed a cleaner install to me.
  7. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    Do you think that drilling the hole in the cage will weaken the cage at all? This is what I would like to do at all three points of the belt.
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    No it will not, you will be welding in a bung so the stength will still be there.
  9. Skigirl
    Apr 2, 2001
    2,563
    What cegus said.
  10. kw48653
    kw48653 Registered Member
    Sep 16, 2003
    86
    if you haven't already purchased the belts
    you can choose the kind that wrap around the cage.
  11. Skigirl
    Apr 2, 2001
    2,563
    Got any pics or sources to buy?
  12. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    As you can see the lap belts are attatched to tabs welded to the cage, my seats are also attatched to the cage. The shoulder belt is a "Y" design and attatched to a tab welded to the tube going across and around the main hoop horizontal bar. Holds very well.
  13. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    http://store.summitracing.com/partd...1&part=BOB-50502-19-23&N=700+115&autoview=sku
    Summit lists a few for "wraparound" ... I imagine Jegs does too.
    Not that I have any idea what it's about, just though I'd search there for ya. :crazy: Mine are bolt-on and this winter when I do the seats-into-the-cage thing I'm gonna weld bungs on, since I already have the harnesses.
    -- A
  14. Skigirl
    Apr 2, 2001
    2,563
    Thanks. Looks like those are 5 point harnesses. In the pic above, they require tubing behind the front seat. I put mine in on the tubing B pillar as I don't have a tube horizontally behind the seat. If I did I think I'd go with a 5 point harness.
