3 position NP203/5 position NP203?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by klier, Apr 30, 2003.
  1. klier
    klier Registered Member
    Jun 19, 2000
    88
    Faribault, Minnesota
    As I understand it, NP203 cases have 5 positions ... Hi Loc, Hi, Neutral, Lo, and Lo Loc. Did some earlier Blazers (73-75) have a three position NP203 with only High, Neutral, and Low? If not, which transfer cases had only these three positions?
  2. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    like dude i would love to help you out here, but i don't even know. sorry.
  3. klier
    Jun 19, 2000
    88
    The reason i'm asking is for your Blazer, dipshit! /forums/images/graemlins/tongue.gif /forums/images/graemlins/thumb.gif
  4. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    oh really i didn't know that. and don't call me a dipsh!t. just because i am one, doesn't mean you have to tell everyone. /forums/images/graemlins/tongue.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A 203 that's been converted to part time 4WD may only have the 3 positions. /forums/images/graemlins/cool.gif But they all left the factory with 5 positions. /forums/images/graemlins/wink.gif
  6. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    but it is a full time case
  7. klier
    Jun 19, 2000
    88
    Me and t-maxxer here both have frames of the same era, and i know mine has 5 positions (and the tag on the sunvisor explains each of the positions). Joe's has 3 positions (and the tag on the sunvisor, from what I remember, explains just the three)
    That's what confuses me so much ... was there a factory 3-position NP203? (The sunvisor did state "FULL-TIME transfer case)
    Oh, by the way, check out Bauer's Pit 2003
  8. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    If it is a 203 then it has 5 positions. Doesn't matter if it has a PT kit or not, still has 5 positions.
    Lo Lock
    Lo
    N
    Hi
    Hi Lock
    Hope this helps.
  10. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    maybe a 205, check the visor again, is the lever round all the way down or does it taper into a flat piece???
  11. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    it tapers into a flap piece.
  12. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Its been to long but I think Ford F-100's only had
    a Trasfer case with High Range !
    If it was Full-time, then maybe High, High Lock, Nuetral
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my buddies dads 73 has L-N-H on his. I think he said it was a rockwell case, same one his 69 had.
    -Jeremy
  14. klier
    Jun 19, 2000
    88
    Hey Joe...
    I think your linkage is definitely out of whack. Here's a graphic I found on how to adjust the linkage:
    And, your case is definitely a full-time NP203. /forums/images/graemlins/thumb.gif It should have FIVE positions. Here we go:
  15. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    the np203 converted to part time still had 5 positions 4wd low, 2wd low, neutral, 2wd high, and 4wd high.
