3 questions. Hydro assist, doubler, and starter
Discussion in 'The Garage' started by 8_YOUR_H2, Nov 10, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    First off, the dirt stick chevy is ready to run. All I have to do is wire it up and put fluids in everything. It will run this weekend!!!
    First question. With the Hydro assist, what kind of fluid do I need to use. Can I get away with using regular fluid or do I need to use synthetic? Could I use Dexron III? I have the resovoir extended and a cooler on it. The pump is tricked out to flow more too, don't know if that matters or not.
    Second question. Neither the doubler adapter nor the 203 range box have a vent line (it is the WMS doubler). The 205 has a vent but it is in its own separate, sealed unit. Will I be ok with no vent. The adapter should have had one in it if I needed it right?
    Third question. When wiring the chevy alternator, can I run the selonoid wire out of the fuse box to the starter button then down to the selonoid with no fusable link?
    It will run this weekend...oh yes...it will run....muhahahahaha
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    My Jeds doubler adapter has a breather in it. I would think that it would need something.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My NWF doubler also has a breather in it.
    Dexron III is what I use.
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    ORD--breather yes
    fluid-I use "something" SynPower. and only that. have had Zero problems
    wiring-- Dunno
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Odd that your doubler wouldn't have a breather...
    Rene
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    As far as the fluid goes, I read a write up recently on tractor fluid that I will be using with my hydro assist. It is supposed to have several advantages including better cooling. It is for sale at O'reillys so I can always get it locally.
  7. Bigdawg234
    Bigdawg234 Registered Member
    Apr 11, 2006
    29
    Leechburg, PA
    I've run my 83 k20 for the past 2 years, and my blazer for the past 6 months without those pain in the but fusable links. And I dont know about the breather or the fluid, but i have read that tractor fluid is the way to go and i would think that it would need a breather, but i aint sure
  8. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I used regular PS fluid. Had an electrical engineer friend come over and wire it for me. Needless to say it works great. Fired right up. The PS pump flows like crazy after doing the pump mods. I am so excited. I might actually be able to go wheeling this year.
