3 questions.
Discussion in 'OffRoad Design' started by elacruze, Mar 26, 2004.
  1. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    1. My 4x4 steering box is...high mileage. I have a 2wd box. Can I install crossover steering on an unlifted '85 K35 6.2 diesel? Can I do it with high-steer arms?
    2. Why does ORD include a PTO cover with doubler? I have a PTO hydraulic pump and I'd like to keep it on the 205 for optional speeds.
    3. I have a slip-yoke 205. Are all fixed yoke 205 parts the same, so I can use a Ford/Dodge 205 to steal the FY from?
    Eric
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I don't think you will fit crossover steering on an unlifted rig.
    The PTO cover goes on the Range box so you have a place to fill it will oil.
    There are 205's with 10, 30, 31, and 32 spline front outputs. I am pretty sure the 10, and 30 spline is a GM only thing, but I believe the 31 and 32 splines are a Ford thing and i'm not sure about Dodge.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You can put the 4WD sector shaft in the 2WD box and it will work the same. Then I will pay you for shipping on the 2WD sector shaft to AZ. x-over will not fit without a lift. It will also cost more than a new box.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't think you can fit the crossover on a stock height truck, and I'm not even sure you'd need it, the GM steering works pretty well with up to a 3-4" lift.
    The PTO cover is for the oil fill, without it, you have to get pretty creative putting oil in the 203. Keeping the PTO on the 205 wouldn't be a problem at all.
    The ford and dodge rear outputs do interchange with the GM slip yoke type shaft, you just have to watch for the speedo gear variations. You will want to keep whatever speedo gear setup you get on the shaft it came with. Later versions have a splined shaft where the speedo gear rides, earlier versions were smooth.
  5. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Speaking of 2wd steering boxes, when I go to crossover would their be a benefit to getting a 2wd box off of a 3/4 or 1 ton as opposed to a 1/2 ton box? Trying to avoid hydro to steer my 38s
  6. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Anyone??? Is the 3/4 or 1 ton box beafier? /forums/images/graemlins/ears.gif
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    They are all the same.
  8. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    That kind of sucks, I figured that though becaue if they were bigger I'd have seen more about them
    Thanks /forums/images/graemlins/thumb.gif
