3-speed or 4-speed?
Discussion in 'The Garage' started by prossett, Nov 9, 2005.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    Dumb question, sorry.
    On my manual gear stick there's L-1-2-3 and of course reverse. Is this called the 3-speed or does the Low gear count as well?
    1983 Jimmy.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    depends on you.... it is a smc465... I have the same thing... L-1-2-3..... most people call it a 4 speed with granny gear :wink1:
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I just call it "bombproof"! :D :D
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's a 4 speed. 3 speeds came with a column shifter. :wink1:
    Older 4 speeds had the shift knob labeled 1-2-3-4. Somewhere along the way I guess that GM had too many boneheads complaining that "1" was unusable most of the time so they changed the label. :rolleyes:
  5. prossett
    Sep 29, 2005
    165
    Thanks guys, that clears it up for me.
    I have stick shift, but also the auto tranny P-1-2-D-R thing on the steering wheel, with the lever removed, so I assume it was switched over to manual gears some time back. The problem is I have no reverse lights, and my Haynes was saying the 3-gear back-up switch was on the steering column, which confused me.
    Now I know I need the back-up switch that goes on the 4-gear transmission.
