3 Speed Transfercase
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, Mar 11, 2001.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    How does a 3 speed transfercase sound? I am looking into making at least one for myself. If this works good I might make more. What kind of gear ratios would you guys like to see. I was thinking something like 2.98 to 1 and 4.69 to 1 or 2.75 to 1 and 4 to 1. How does that sound. Please let me know what you guys think. Thanks
    Donovan
    <A target="_blank" HREF=http://www.rustbucket.coloradok5.com>http://www.rustbucket.coloradok5.com</A>
    Bigger is Better
  2. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    Without giving up your secrets can you give me an overview?
    David
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    What case are you plaining on using?
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  4. Donovan
    524
    Arvada, CO
    My own cases with the front adapter of a NV241. It will I hope have the strength of a 205 and maybe 1" longer than the 205. It will have two shift levels. That is about all I call tell you for right now.
    Donovan
    Bigger is Better
  5. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    I think you'll have alot of interested people including myself.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  6. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    When do you plan to have this thing up and running?
  7. Donovan
    524
    Arvada, CO
    I will have to build everything for it so it probably will not be before the end of summer but it could be sooner. I have to see how the work load at my work goes. I have to talk a little harder to the Boss to put some money into making the gears. Oh my boss is my Dad so I shouldn't have to talk to hard. [​IMG]
    Donovan
    Bigger is Better
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    How about something lower than the 4 to 1 range? Many of us run stock gears and cant afford gear swaps. So, if we had a lower than 4 to 1 range, we can run taller tires with those punky highway gears.
  9. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Yeah, how about, if possible, a 1:1, 2.5:1, and 5:1. Are you planning to use planetaries or strictly all gears? I would be very interested in one. Be great if you could keep the price under an Atlas, say in the $1,000-2,000 dollar range. Keep us posted.
    ken
  10. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I'd be interested. Do you have a target price range in mind?
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If I was designing it I would go with 3:1, 1:1, .7:1 O/D. Just a thought.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    Having it incorporate a 2WD OD range would be nice since Blazers don't have enough wheel base to bolt any extra gearboxes under them and that would be great for TH350/400 owners.
    How about a 1.3:1 range for 2WD and 4WD so that it also kills the problem of needing to swap axle gears? I know that it would put more stress on the driveshafts/'case and tranny than swapping in the right gears and using a 1:1 'case, but some people might consider that to help justify the purchase, since it could save them about $1000 worth of gear swap. Of course, for those people, a 1:1 range would be like overdrive anyway and having the higher axle gears would keep the driveshaft speed down, exaggerating less any problems due to big U-joint angles.
    Just some ideas, personally, I don't think I'm in the market. Cool project, though.
    <font color=green>Stupid tourist at Mammoth Cave, Kentucky: "How many miles of unexplored passages are there?"</font color=green>
  13. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I agree with Ken, a 1:1, 2.5:1 and 5:1 would be awesome! I will definitely be in line if it comes out like that! I was waiting for money to put in a Doubler, but if you bring this out I will definitely give it a shot! Keep us informed, please!
    Keith
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Personally, I don't see the need for 2 low ranges although an extra-low and an OD might be nice. However, this is a *HUGE* project and I can't imagine it being completed in 6 months.
    Anyway, I would be happy if someone would just figure out how to get a lower low-range in a 205 without doing a doubler.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  15. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    I remember reading in 4-wheel, I believe, somebody makes a doubler that is 3-speed. It bolts between the tranny and t-case. It had two low gears 2:1 and 4:1 and an overdrive about .7:1 I think. Neat thing was it was Eaton air shifted. They installed it in a Ford Ranger x-cab so it was't too long. I think the issue was in the last couple of years. I know you're trying to do a single t-case but the possibilities with this are intruguing. Good to 1000 ft-lbs I think too.
  16. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Man that sounds perfect.
    Jim '80 GMC
    Freedom First!
  17. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    That was the "Brabnod Mountain Gear Auxillary Transmission"
    Deep under 3.258:1
    Second under 2.575:1
    Direct 1:1
    OD .79:1
    Air shifted, so you'd need OBA, straight-cut gears and a torque capacity of about 1500 lb-ft!! And the whle thing fits in a package just 14" long. What's the down side, you say?
    $3500.
    Not including the installation and custom fabrication needed to get it to fit and work right. They did have a smaller, cheaper 2-speed intermediate 'case that was a .85 o/d and 2:1 low, but it was still around 1200 for it.
    It was in the Sept. '98 Four-Wheel and Off-Road.
    It would be bad-ass, but I don't know how you could get it to fit in a blazer. Maybe if you, moved the engine forward and stretched the wheelbase a few inches.....
    Damnit!! Now you got me thinkin'!!
    HTH,
    Buddy
    72 K-5, 33x12.5's, 350/350/205,12-bR,d44F soon to be 39.5'x15.5s, EFI502/nv4500/doubler205, d60F, d70R. Stay tuned.
  18. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Ouch, thats more than I paid for my whole truck. I think I stick with the doubler.
    Jim '80 GMC
    Freedom First!
  19. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I'd have to agree with Ken. I like the idea of 1:1, 2.5:1, 5:1. Somebody needs to come up with a lower gear for the 203 gearbox or the 205 case that would be enough for me.
  20. Donovan
    524
    Arvada, CO
    Ken I am planning on all gears for now, but I have looked into planetarys also. They are a little more expensive.
    Donovan
    Bigger is Better
