3 welding questions...
Discussion in 'The Garage' started by firefighter184, May 11, 2006.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    1) Is a 110 wire feed enough to weld new spring perches on my 14bolt? Specifically the DIY4x perches.
    2) Is a 110 wire feed enough to do a slider/rocker replacement? I'm getting 10 feet of 2x3 3/16 wall square tube for $20.00, so I'm gonna try and make some sliders.
    3) I'm picking up a 1-ton 14bolt Saturday, which I believe has a Gov-lock. Can I Lincoln lock this thing with a Gov-lock? I'm planning on going to 4.88's next spring, and a Detroit, but for now I just wanna wheel what I got.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    As to #1, look in the vendor section, he is coming out with something new....
  3. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    I couldn't find it. Where in the Vendor section?
  4. cbbr
    Jul 17, 2004
    14,681
  5. Art'74
    Art'74 1/2 ton status
    Dec 21, 2004
    145
    OKC
    I will answer this for a Lincoln 135 w/ .035 flux core wire.
    #1 - it is good to 1/4". So if your application is within this parameter you are good to go.
    #2 - See #1
    #3 - I don't know.
    Hope this helps.
  6. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I do a lot with a little mig but no way I'd do the spring perches with it. The sliders, With some carefull beveling and take your time ( duty cycle ) maybe. If a slider falls off, no biggie. But the perches, tack 'em where you want 'em then transport it to a place where you can get 'em burned in right.
    A trick I used on my little lincoln was I added a external cooling fan to move more air thru it. Seems to give me a longer duty cycle.
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I did mine with a lincoln 100. worked fine and survived a few 400hp burnouts in 4lo!:doah::doah:
  8. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    the 14bolt gov lock is a pretty stout unit, the ones that give ppl trouble are the 10 bolt ones.
    If you want to just get out and wheel, i woudl run it for a while.
    But yes, you could easily weld up a gov lock with a wire feed......just take your time. Not exactly a huge saftey issue if it does happen to break anyways.....
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1. Yes
    2. Yes
    3. Yes
    A decent welding machine in the hands of a good welder is capable of alot of things. If you ever meet az-k5 look at his rig. 95% of the welds on that truck are done with a welder that you would laugh at and never think could have put that truck together. If you are not a good hand at welding then find someone who is to weld the spring perches on and weld the 14bff. To weld a govlock you basically weld everything to everything as best you can and hope it doesn't go boom. Melt all the stuff together and you should be good.
    Harley
  10. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Seems like there must be a trick to welding up an axle. I welded the pinion to the ring gear on the gear set that broke in Moab - you know a conversation piece:D - and I noticed most of the tacks have cracks in them.
  11. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, I'd say go with the flux core and crank up the heat. Here's some DIY4X perches welded onto a 14Bff with a millermatic 110 wire feed.
  12. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Looks good to me.
  13. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, I cleaned my mask, and it was as if I gained experience at the same time. I was pretty happy about it, too bad none of the stuff on my truck looks that good, as it was a buddy's axle. I think that you can get most things done with a 110 if you're using flux core though. One of the bit differences was welding with a real extension cord, not the cheasy retractable one. Also shutting off other things...like the 500w halogen light, or stop your buddy who's using the angle grinder 10 ft away...gives you a lot more power.
  14. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    You got that right, I made a big ass gauge, short as I could get away with ext. cord. It makes a big difference. Add a little fan to the air intake grill and push more air, you can weld longer between cool downs. I use .035 flux wire and the " good stuff " not the harbor freight stuff. Tried it, did'nt like it.
  15. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    Now,thats some nice work!!!!
