30 gallon fuel cell?
Discussion in 'The Garage' started by sled_dog, Dec 30, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Anyone seen a decently priced fuel cell in this neighborhood? I'm just thinking about my C2500. I want to do full true dual exhaust(with a crossover), but the fuel tank is DIRECTLY in the way of doing that. I also need to replace my high pressure lines since both they and my fuel filter are rounded from the last time I tried to replace it :doah:! So just a thought. Does anyone know of a large capacity fuel cell that contains an internal pump? Maybe one that just accepted the factory fuel module setup from my present tank?
  2. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Will a K5 tank fit between the rails in back?
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    absoluetely, framerails are wider on the NBS rigs. Wondering if the factory fuel module will fit in. TBI fuel pump wouldn't cut it, being as a Vortec truck needs a minimum of 50psi to run, 55-60 to run happy.
  4. bear76
    Oct 16, 2005
    1,065
    here
    I would run an external pump.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Wouldnt this money be better put towards the s-10?
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    just run both pipes down one side. I have seen it done. then turn the mufflers on their sides. or just use the factory Y as your crossover spilt it again after that and run them both down the same side.
  7. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,851
    280
    Truckee, CA
    Sounds like a lot of work to me. But you could look into a combo toolbox aux tank setup, and use it with an external pump for a primary tank? I think that woudl work, wouldnt' it?
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    could be doable and I've thought of it many times. The 97 has a full dual exhaust back to the muffler(no y-pipe).
    I am sick of driving a quiet truck. I used to be known for my K2500 and my Suburban both being the loudest things that went no where quick. I just need some noise out of the damn thing.
  9. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    I bought a 32gallon Fuel Cell for $180.
