30 spline 10 bolt and 30 spline D44 interchange?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Root Moose, Jun 7, 2003.
  1. Root Moose
    Root Moose Registered Member
    Oct 23, 2002
    11
    Are the 30 spline 10 bolt and 30 spline dana 44 completely different axles? Is there some interchange of parts?
    I'm probably confused by what I've read about the 10 bolt being the GM version of the Dana 44. Maybe they were meaning comparable, not version...
    I ask because I have some 30 spline D44 ARB lockers, just wondering if these can be installed into a GM 10 bolt axle.
    Any one know for certain?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Only things that interchange is everything from the knuckles out. The axles, ring gear, carrier, housing do not interchange.
    Forgot, Stub shafts and U-joints interchange...
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    yep, from the knuckles out and the stub shafts.
  4. Root Moose
    Oct 23, 2002
    11
    Thanks guys.
    I was hoping there would be more interchange but oh well.
    I guess now I will have to sell them to buy a D60 ARB. I can't see swapping in a D44 just to use the locker. If I'm going to bother with it I might as well go with the D60 and make the swap worthwhile.
    Just out of curiosity, what is the going price range on a D44 front axle these days?
    T!
  5. Root Moose
    Oct 23, 2002
    11
    Is the 10 bolt the same strength as the D44?
    r@m
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Other than the housing and tubes, they are the same strength.
