30 spline Rear shafts needed
Discussion in 'Rocky Mountain Region' started by NateInChandler, Mar 2, 2007.
  1. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    hey guys, i need some 10 bolt 30 spline shafts asap, i messed up on a diff job and assumed it was a 30 spline carrier (took out a gov-bomb), well, was i wrong, truck wont move, haha... must be 28 splines... so i need 30 spline shafts or a open 28 spline carrier for 3.73's.. PLEASE let me know at 480-209-2949.. Thanks.. nate
  2. NateInChandler
    Apr 23, 2006
    418
    Chandler, AZ
    none has any stock 10 bolt rear shafts??
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If it helps ALL gear ratios from 2.73 to 4.10 take the same carrier . So don't limit the search to just 3.73 gear carriers .
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The carrier break for 10 bolts is 2.73+ like you mentioned but it does not stop at 4.10. Anything 2.73+ uses the same carrier even 5.13+.
    Also a 28 spline carrier out of a 10 bolt front axle will work in the rear.
    Harley
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I may have some.... :dunno:
    Lemme look.
    Marv
  6. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
  7. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Nevermind - I thought you wanted a 12 bolt.
