30' travel trailer and Shortbed K10
Discussion in 'Tow & Trailer' started by 85scottsdale, Feb 24, 2005.
  1. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Anyone know if this will work? The truck is an 85 K10 which will soon have 4.10 geared 3/4 ton axles under it, 350 engine with lots of bolt-ons, 700r4 transmission with some upgraded parts and the biggest street cooler B&M makes. Anyway, its not the drivetrain i'm worried about, its the wheelbase and whether the truck will handle the trailer.
    I have a Class V hitch and load distributing hitch and anti-sway bar for the hitch setup, truck still needs brake controller, but i'm going to install one anyway.
    The biggest load i'v towed with this truck so far is a 2k lb u-haul car trailer with a 82 RX-7 on it that weighed in probably around 2500 lbs, so it was about 4500 lbs and it towed fine even with 3.42 gears and 33" tires, I ran about 70mph on the highway with it.
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Wheelbase is too short, and the trailer probably weighs more than your truck. IMHO. I don't think you will like how it handles. More than likely you will smoke your 700R4 as well. Sorry, just my .02
  3. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Well, i'm not worried about the 700r4, I built it myself and it should be ok with the big cooler and I also have lockup in 3rd gear.
    But I figured the wheelbase would be too short, i'v towed it with a 97 burb with 5.7L vortec and 3.73 gears and it pulls ok, but its got a good bit on wheelbase.
    I'm not sure what the actual weight of the trailer is, but my truck weighs 4660 lbs with no spare and no people and only 9 gallons of fuel, basically 4660 completely empty.
    I think your right about the wheelbase either way, too short for a 30' trailer.
  4. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I agree that the wheelbase is a tad too short. I used to tow a 23' travel trailer with my K5 with 4" lift and 35's. It handled OK with the load equalizing hitch and bars, but 30' is getting a little too long. Same travel trailer towed with my 97 ext. cab longbed is so different with the long wheelbase of the truck.
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    i tow a 30' TT with a 91 sub, and i'm thankfull for every inch of wheelbase! I've also got a Class V on it, but with the style bumper (ranch hand), it effectively moves the pivot point back about a foot or better which is something i don't care for at all. Guess there's a formula about length of TV & TT and even with the sub, i'm a tad short of the 'recommended' w/b for a 30 footer!
    I wouldn't even try towing 30 feet with anything shorter..... (just my $$00.02 worth, but that's a PRE-TAX figure).. :)
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    How much does this trailer weigh? Your 700R4 should be plenty happy, I wouldn't worry about that.
  7. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Its GVW is rated at 6k lbs...
    And like I said, the 700r4 has 12k miles on it, corvette servo, .500" boost valve, shift kit, and a 24k lb B&M transmission cooler.
    The truck is physically capable of pulling it, I just don't think its long enough to actually keep it under control well enough.
    I really need some 4.10 gears, after the 4.10 gears I should be able to pull anything, especially if I get the motor I might be working a deal for!
