$300 to a mechanic, and a new problem...*AND PIC OF MY TRUCK*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lotsa_Faith, Dec 23, 2002.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    Got a bunch of stuff fixed up Wednesday (vaccum lines, choke rebuilt, fuel lines, dustributor cap and rotor). Ran fine for a day. This morning, tried to take it out duck hunting and found a new problem. It ran perfect for about 2 minutes, then it started bogging like crazy. It sounded like it was running on 2 cylinders, and black smoke was coming out of the exhaust. Then after a couple of minutes of that, it would go right back to regular, running just fine for probly 30 seconds, then back to the 2 cylinder chugging. Anybody got an idea? The mechanic said that the carb needed a rebuild, so could that be the problem? But why would it only start doing that AFTER everything else was fixed?
    BTW I finally got a pic taken of my truck w/the SX's on...no lift.
    My M1009
  2. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Re: $300 to a mechanic, and a new problem...
    Take it back to him!!! The choke is sticking closed when it should open causing it to load up , i.e. the black smoke. Probly feels like a H /forums/images/graemlins/grin.gifarley rough as hell
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yep, Its the choke. Sounds like it might not even be hooked back up right. Just flopping around maybe.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Choke.
    My K30 does that every now and then. Needs to idle longer and get warmed up properly before just taking off and drive.
  5. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    Wouldn't headers eliminate the choke thats right behind the manifold? I need some of those anyways. They said the choke was in bad shape, and they rebuilt it the best they could. I'm still gonna take it back to them and let 'em look at it.
  6. ccox7
    ccox7 Registered Member
    Jul 24, 2002
    69
    Bayou State
    Usually you have a choke pull off which has an adjustment too.Your mechanic may have to re-adjust it to where the opening is a little wider.They can be finicky to deal with.
    /forums/images/graemlins/thumb.gif one other thing is to check the choke pull off with a vacuum pump to see if it is holding vacuum.
  7. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Wire it open and call it goods.... then save up for a fresh carb
  8. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Sorry yer havin' such a time with yer truck...I know how frustratin' that can be...s'posed to be really nice this weekend, so either give me a call, or I'll try to call you....I bought a heater for the garage, so if ya want to look at it some evening we can do that, or just wait for the weekend...either way.....I have to go to FTW Sat nite, and leave here about 5:30 (takin' the wife to see Tuna Christmas)...
  9. twenty_below0
    May 16, 2001
    436
    I second that idea, wire it open, be alittle more pain to get warmed up but should run better over all. Good Luck /forums/images/graemlins/thumb.gif
  10. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    What exactly do you wire open to fix it? I need to get it out to K5Jimmy's house to fix it...right now it will barely crawl...
  11. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    I also got a 4" lift for X-Mas (courtesy of shupach)...
