305 AGAIN
Discussion in 'Other Rides' started by COOTER, Jan 30, 2002.
  1. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    Can i put 350 heads 0n my 305 ,and what will it do for me?
  2. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    You can put SBC 350 heads on a SBC 305. There are so many different valve sizes and combustion chamber sizes that it may or may not be beneficial. 350 heads with larger valves may flow more air, but they may have a larger combustion chamber that would reduce your compression ratio.
    Check what you have vs what you can find before you do a swap.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    MOST 305'S USE A 58CC HEAD. AND MOST 350'S USE 78CC HEADS (64CC HEADS ARE AROUND, BUT THE 78CC ARE THE MOST COMMAN) YOU'LL LOOSE COMPRESSION WITH THE 350 HEADS. I RECOMEND GOING WITH THE 58CC 305 HEADS. YOU CAN HAVE THEM REGROUND FOR LARGER VALVES IF YOU WANT TO, BUT YOU'RE DEALING WITH A 305. IF YOU'RE WANTING POWER, LOOK INTO DROPING A LARGER ENGINE IN PLACE OF THE 305. YOU CAN DO IT PRETTY CHEAPLY BUYING THE MOTOR FROM A SALVAGE YARD.
