305 and 350 Flywheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Skroo, Dec 19, 2002.
  1. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    Is the 305 flywheel the same as a 350.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They are interchangeable, as long as both are for the same rear seal type crankshaft.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yes. Only the 400 is different, and the 454 is different again. All the same diameter, but different balance.
    Watch out for a smaller 153 tooth version (trucks are 168 tooth). They were used mainly in cars, and require a different starter. It will also work on a 305/350 or any other small or big vlock engine besides a 400 or 454.
    P.S. Blazer1970's comment is valid as well. /forums/images/graemlins/thumb.gif
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Remember, the new 1pc rear seal motors have a different bolt pattern than the older ones. I think it was all 86 & newer engines have 1pc seals. As long as the 2 engines fall within the same year split (both 1pc or 2pc version)you will be OK. Hope this helps.
    Lonnie Pavtis
    Lonnies Performance Automotive
  5. Skroo
    Jul 13, 2002
    137
    Houston, Texas
    Cool. I just have to check the engine I'm getting. Thanks.
